Moderators
m16ty
218
Dickson,TN
Any member can add to/edit the article. If you see something missing, feel free to add it.
3dubs
Houston, TX
is that the hummer's engine?
It covers HMMWV and CUCV 6.2 and 6.5. It is really helpful. It will also help if you get a HMMWV engine and put it in your CUCV. I was trying to replace O-rings on the throttle shaft of the injector pump. I looked at it and thought I figured it out but did not want to break anything. After searching the CUCV TM's I went to the internet and found the other TM and it explained very part of rebuilding the IP. I found that I was right in what I thought would work. But I figured it could help other people too. It explains pre 1990 or 1990 on. It is not CUCV specific but it covers the engine down to much more detail. I like how it tells you in each section what tools you will need.
