TheDoubleDeuce
- 0
- 6
- Texas
Hello again everyone!
I recently removed the push-button ignition and put a universal keyed ignition in the Deuce. On the ignition there are hookups for:
Battery
Accessory
Ignition
Ground
There were only two wires hooked up to my push-button starter. I hooked them up to Ignition and Ground, and it starts up. The thing is, it doesn't start like a normal car - I turn the key to the on position until it starts, then back to the off position to turn off the starter. I can pull the key out of the truck while it's running. I understand this is similar operation to a push-button ignition, but do you think there is any way to get this to start up like a normal vehicle and leave it the key in the on position while it's running?
Thanks
Battery
Accessory
Ignition
Ground
Thanks
