- 359
- 26
- 28
- Burdett NY
Just won a Hubbell SBSB2 50amp spider box!!! Started to price out SO & SJ cable and decided this in the long run was cheaper and had more options. Suggestions on how to come off the Mep002, spider>then to the house or just use the 50amp cable dirrect to inlet outlet w/ interlock. Thanks Bob.
Hubbell Wiring Device-Kellems Product Specifications Product Type Spider II Temporary Power Distribution Units Primary GFCI Protected Receptacles 6 - 20A Straight Blade Receptacles Secondary Receptacle Protection 30A 250V Twist-Lock Receptacle - GFCI Protected Rating 50A, 125/250V AC (max.) Listings/Certifications UL 1640 c-UL and CSA NRTL/C Operation Indoor and outdoor wet and dry locations Enclosure Type 3R, rainproof, suitable for use in damp locations Code Compliance Article 305 of NEC®, ANSI/NFPA 70 (NEC®)/NFPA 70 (NEC®). Moisture Resistance 3R, rainproof, suitable for use in damp locations Operating Temperature 66°C max.; -35°C min. w/o impact Cover Plate Gasket Material UL recognized closed-cell foam (aging and oil resistant)
