hdexpert
- 8
- 18
- Worthington Ohio
Was having trouble starting the deuce, got worse, took lots of cranking and pedal feathering. Changed all filters, in tank pump works well, looked for leaks, kinked lines-nothing!! So with some consultation from those who know we decided I needed to replace the hydraulic head. Got a rebuilt unit from a friend, installed it-same issue. Took it out, timed everything correctly-same issue. Loosened all lines at the injectors, cranked it over and fuel just dribbles out. So I did some more calling to the ones who know about this stuff and we thought maybe the HH was faulty. Installed another rebuilt unit, same issues. Talked to Gimp today and decided we need to replace the IP. My questions are what goes wrong inside the IP that would cause low line pressure and being a LDS do I need to replace the IP with a LDS IP? I'm at my wit's end and it's getting cold here!! Any ideas???
