jimh1985
- 0
- 0
- lizella, GA
This is the first post I have done so be gentle.
I have a question about bobbing my deuce. I don't know a good way to explain this but in the rear you have two tandem axles. the spring sits in between them.
Would it be possible to remove the rear axle and make some kind of brace to come down off the frame and provide a loop for the rear end of the spring to rest in. as if the rear axle was still there? I realize this could look a bit strange but It would also provide the most heavy duty suspension possible. Not to mention the easiest bob job ever.
