Ferro got a tank
neilhendrix
Reidsville N.C.
Gimpy stole my coment rofl>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>When we going to paint it ?
Speddmon
Blind squirrel rehabiltator
Cambridge, Ohio
Way to go Adam. That's a sweet looking addition to the "818 of DEATH". Now, are we going to see a load of Ferro's "special" deuce elixir at the Haspin rally this year, and start a price war with Doc????
jasonjc
290
Gravette Ar.
Take that tire off and look for extar stuff in it. I heared more than once of a G.I. puting a tube in a tire that all ready had one rolled up in it.:shock:
Almost for got nice trailer. I seen those too and drooled. I'd love to have a tanker for my 5 ton.
EMD567
Driver for the Ga Mafia
47
Aiken SC
Tanker tows very nice EMPTY behind the 5 ton. I told Ferro that we now have enough fuel capacity to get my 814 and his 818 to Haspin and back, no stops.
I couldn't get over the tires- still had the overspray from the CARC paint, applied 11/04 :jumpin:
Ferroequinologist
Resident railroad expert
742
Liberty Hill, SC
I will probably pull the wheel off and see if I can tell anything from the outside- it might just be a bent rim.
LOL I might have to get my doubled endorsement and haul it, and Neil's houch to AK. No worries about fuel!:driver:
emmado22
148
Mid Hudson Valley NY
DO NOT trust that overfill prevention valve.. Ask me how I know.
Dont forget to chage the Filter Seperator socks also. Who knows whats growing in them.
zout
154
Columbus Georgia
heck with sweet tea - gut that baby out - mount troop seats all around it - split that baby in 1/2 with hydraulic lift arms and make one sweet big A** BBQ texan style grille outta it - leave the back open with a ramp so all you have to do is herd pigs or cattle in there and gut em out at the rally on the Hickory tree.
I'll make the liquid refreshment and BBQ sauce.:jumpin:
This is Adam at the rally: :deadhorse:
Ferroequinologist
742
Liberty Hill, SC
lol I've gotten the 'let's make a grill out of it!" comment from several of my friends already!
Oh, I don't trust anything like that emmado, I was in the Navy as an oil king! I plan to install tank level indicators and a panel at the valve tree so I can see how full it is. Just floats and lights. And I will always use the eyeball method or a 'soldier B'
Oh, and it is a Heil.
Trailboss
138
Norwood LA
I drooled over them when they came up, congrats. If only they were a little closer.......
I'm hoping some will shake loose around here, but I'll probably be working 2500 miles away when they do.
Josh
12
Portland, Oregon
I swear I remember reading a story on here about someone aquireing a tanker like that still full of diesel, talk about a score.
Fun fact - If your 5ton got 6mpg with a full tanker, you could drive around he planet once before ya had to stop for fuel.
Ferroequinologist
742
Liberty Hill, SC
It still has probably 10 or so gallons of old JP-8 in the lines. Plan to drain it out and burn it in the deuce.
I did a 300 mile trip, 1/3 bobtailing, on one 55 gallon tank, and still had some left in the tank. I'm sure it will be a whole tank one way when she's loaded!
fasttruck
633
Mesa, AZ
5000 gallons of gas or diesel weighs about 40,000 pounds or so so your gross will probably be abouty 75,000 pounds going down the road. Brakes work ? Tires inflated ? Placards and MSDS as required ? Placarded trucks are definetely bear bait thesed days.
OSO
Arlington,Wa
I lived in Milwaukee back when those were being built. Would drive past the Heil plant and see about 20 tanker trailers out in the yard. All painted up with camo pattern.2cents
Alredneck
Banned
1,494
15
TN
Awesome, glad you were finally able to get the means to keep the side work going. That bio/veggie gig sounds pretty sweet! Hope it all works out and everything is going well out yonder!
Ferroequinologist
742
Liberty Hill, SC
load of WVO at 7.5lbs per gallon, 5000 gallons- 37,500lbs.
Empty Trailer weight- 13,000lbs
Tractor weight (m818)- 19,644lbs
Total- 70,144lbs
WVO doesn't need placards. Before I start backhauling the bio blend (which is placarded) I would like to get a m915 and I still need my hazmat endorsement, so I'm studying for the test now.
Brakes are new, one air line to one can needs to be replaced it's fraying a little, other than that, they work great. Tires are brand new. I need to check out the wobbley one.
The trailer was basically parked after rebuild in 11/04.
