- 2,883
- 1,490
- Czech Republic
There is a line of material about a cm thick between the main frame and the dump sub-frame. I thought it was metal, but today I took of a piece sticking out and found that it is wood?? It that normal?
Yes, they all have that.There is a line of material about a cm thick between the main frame and the dump sub-frame. I thought it was metal, but today I took of a piece sticking out and found that it is wood?? It that normal?
You should look at the patent linked in post number 9 for your projectHow did this project turn out?
