kennys@wi.rr.com
- 23
- 38
- Waukesha, WI
So I've spent some time today looking at my filters and reading the threads and even watched some videos about spin on filters for the deuce. I know I can spend a few hundred dollars and get all the spin on adapters I need and be done with it. However, in my reading I've seen something kind of cool looking done with the oil filters. I saw a few people mounted a spin on filter to the firewall and ran a line to the top of the original oil filter canisters. How is that done and what mods are needed for this? I would be all over the spin on oil filter kits if I could relocate the oil filters to come off open side up. I know I can buy the filters that will mostly drain so it's not as big of a mess, but I want options.
As for the fuel filters it looks to me as though the filters are on a mount that is bolted to the block and I could simply remove the mount and put in a spin on mount like they use for fuel transfer tanks or that sort. I know that just because it looks that way to me I can be very wrong and that if I was to try this I would screw something up. Is this an option, is there a better option?
If you have replaced your original filters with a spin on style and you have not used the ready made kit please tell us all how you did it and pictures are always a plus.
Thank you all.
Thank you all.
