panshark
- 11
- 18
- Idaho Falls, ID
for duece owners, just wanted to take a quick survey of where anyone's found a fuel leak at, and the steps they took to remedy it.
no, not yet, I hope I don't see any fire on my truck. Besides a runaway engine situation, has anyone else ever had an engine fire or electrical fire on their duece?have you ever seen a fuel fire on a deuce??
tom
I changed my copper line from the primary filter to the rubber hose on the IP also. I thought about replacing that hose also just because it looks a little wet around the hose. Was your hose in the IP leaking? How hard of a job is that to do? Where did you get the hose? it seems like a hydraulic shop could make a new hose as it seems like standard use fittings.Just replaced the line from the primary fuel filter to the IP on my 1962 M35A2.
The part that went bad was the rubber line closest to the IP.
