deuce10x10
- 0
- 1
- Chapel Hill, NC
I wonder how it will affect a transmission when below freezing? I'll try it and report back.
Do you have a bulletin or something?using lucas is a lazy way of not wanting to perform maintenance. i work at a truck shop (detroit diesels and mercedes benz engines). lucas is very messy to work with. lucas gets into the pores of your skin. detroit and mercedes tells us not to use it in the engines at all, because it will clog up the passages in the engines.
Banana peels also work to quiet an engine. An old, used car salesmans trick is to dump in a heavy oil to make the engine sound smooth.(probably used the banana peels if it was lunch time).ya I have used it in my M109 makes for a quiet running motor. I wonder what happens with below 0 temps ?
Unless temps get above 200F+ the sulpher is inert and will not get acidic (you also need water in the oil) in a transmission. This is pretty much a known fact.Tinwoodsman, I called Lucas and they said it has no sulpher in it and so it is yellow metal safe. I tried to put it in my transmission but that stuff is so thick and sticky. Gave up and went with straight GL-1. Glad i did.
