- 2,960
- 30
- 48
- Tiro, Ohio
Some of the master cylinder caps are already tapped for a 1/8 fitting, makes the install a little easier.
I would not use brake air line for this!
I bought my parts through mcmaster-carr. made sure everything was rated for hydraulic fluid.Did a little reading on this before answering this! they do make a plastic line for brakes/ clutch use. But the air lines like are used on my road tractor will not hold up to prolonged exposure to brake fluid! so if you want to go plastic make sure you get a line rated for that use! I prefer metal but that is just me!
