BFR
Rocket Surgeon
- 2,330
- 42
- 48
- North Georgia
very nice, can the outriggers touch the ground?
Man! you drove right by me. It would have been a riot with my neighbors had you stopped by.
I could have been like "seee what I could have. The duece isn't that big!"
Are you gonna bring that on the convoy next Summer?
Where is your business at in Spokane? I am up there all the time.
Almost forgot, I am a home based business in Spokane valley, I usually have between two and five trucks at any given point to be built or bobbed. Thank god my neighbors are kosher. You can call me anytime and come see my toys and what I do. 509-270-1998 You are gonna die when you see what I am doing with the little space I have. By the way, I am wrapping up a bobbed winch deuce here pretty quick if anyone is interested??Man! you drove right by me. It would have been a riot with my neighbors had you stopped by.
thanks Reb, where would I find that? Is there boost pressure going to the ip somewhere?
Jeff
great idea, I posted that about half way down on page 2. I am going to get some pipe to go around the pin and box in some hinges and weld a u bolt to the front of the bed to manually dump.Nice build..Looks like factory...i keep looking at that bed and the empty roller and thinking if you made some mounts to hook the back of the bed to the old roller pin.and put a mount on the front of the bed you could use the truck as a dump to..The crane could be used to lift the bed to dump it and to load it
No worries, I actually have a complete hydraulic dump bed assemble that I built with a sub frame similar to what the 817's have and decided not to install it. I know it is a little vain but the bottom of the cab and bed are soo close in height that if I add another 8" in sub frame I think it would have looked tacky and since this is a business what I drive represents my work so I will put that dump setup on a deuce or something for a customer instead.Sorry must have missed that part I was distracted by the bad ace truck in your pics........I like it keep up the good work
Yeah that is a good idea, I am looking for a good 5 ton front winch (will consider part trade for the winch or tag axle I took off) to mount on the front of the truck, I will make a custom winch bumper and convert it to hydraulic with the controls in the cab. I am also looking for an eaton fuller 13 or 18 speed if anyone wants to do some trading. As far a the rear axle goes, I have considered singling out the rear tandems sine that would be more appropriate weight wise but since the tandems are bulletproof and both rears have detroit lockers I have a hard time sacrificing performance for comfort. Plus the odds of finding 920 front springs would be near impossible right now.Good looking build. You one uped me with the the crane and welcome to the 920 cargo club. I did use a drop side bed though and am looking for a crane to mount. You could use your winch on the back end of the truck. I was thinking this. With a crane that reaches the rear of the truck you could remove and store the winch and not make it fixed. The winch could hang on the rear by short chains. I took off the roller pin and run big shackles in the holes. This would be a strong point to secure the two top mount chains for the winch and just one chain off the pindle or off the bottom shackles with two chains.
If you realy want to go out there have Hyd. front and back and the winch can be moved and just pluged in front or rear. The crane realy makes this truck. The only problem I see is the beds are so small it will be hard to overload the axles.
Yeah I would agree but when it comes down too it this will only see minimal at best off road, nothing like what I do in the deuces etc. If I were to get stuck and needed to back out I could use the crane as an oversized come a long and pull my self out 38' at a time, the front winch would be more for recovering others or pulling bldg's down or, well you get the idea.If I had to fix mount a winch on these beasts I think the rear would be a better place. Might be better to pull yourself out the way you came in?
