EagleWrench
- 0
- 0
- Sparta WI
everything worked fine until iunbolted the Fuse box to work on the guts of the Heater fuse connectors. When i bolted it back up it started up once. I truned it off and then turn the key back on and all gges just went dim to nothing, I have 12 volts in both Batt, I have 12v at junction block . AM i missing a fuse some where all links look good and test out fine. COuld it be the Starter relay producing this fault?? WHat powers the ignition switch the junction block? ANy help would be great plowing 18 in with a 3 pt back blade blows!!
EagleWrench
EagleWrench
