vacuum and boost gauge
dittle
72
Albia, IA
When I posted a picture of my gauge with both on it someone commented that it might show a plugged air cleaner if all of a sudden the gauge started showing a vacuum. Don't know if it would happen or not but sounds feesible.
mojeeper
St Joe Mo
thanks for the info
I suppose it could work that way I think Ill use just a boost only gauge
rchalmers3
Half a mile from the Broad River
30
Irmo, South Carolina
When .... it might show a plugged air cleaner if all of a sudden the gauge started showing a vacuum.
I once measured the air filter restriction sensor on my Landcruiser and found the sensor tripped at less than 3 inches of vacuum, below the noticable deflection of the gauge, so I doubt a "normal" gas engine vacuum gauge would serve as a reliable filter restriction indicator.
Rick
dittle
72
Albia, IA
Don't know in all honesty....like I said someone else posted that and I'm just repeating what was said. Mine is a 0 - 30 gauge in the vacuum side. I have noticed that when going down hill and I let off the pedal to prevent over-reving it the gauge goes clear back to 0 boost and maybe just into the vacuum side. Never looked really close as I don't want to drive off in the ditch.
Jones
Sacramento, California
If you have a hand-operated vacuum tester (like you'd use to check vacuum advance modules on gasser distributors or smog EGR valves) you could test the air filter restriction indicator on the air filter housing of diesels.
Once you know what vacuum it takes to trip them, you'd know how much good a vacuum gauge would do.
cranetruck
77
Meadows of Dan, Virginia
The filter restriction gauge on the deuce will start to show red at about 20 inches of water. I believe that it may even be marked as to the calibration.
steelandcanvas
86
Southwestern Idaho
With that said, Bjorn, is there any conversion from water column inches (WC) to vacuum in inches (Hg)?
Ooops! Looked it up myself in the conversion tables:
1 Water Column [inch] = 0.073 555 912 462 inch of mercury [0 °C]
mojeeper
St Joe Mo
OK guys thanks for the replies I think I will use a simple boost gauge that goes up to around twenty or twenty five and a pyrometer
gimpyrobb
dumpsterlandingfromorbit!
27,786
758
Cincy Ohio
Might want to get one that reads up to 30. I have seen members post that they get boost up to 27 and 30 psi. Your truck might not, but it would be a pita if it does and your gauge shows pegged all the time.
mojeeper
St Joe Mo
that don't sound like a bad idea I just wanted to see the move a lot
Thanks Gimpyrobb
