motormayhem
- 6
- 18
- Tucson, AZ
When I was driving home tonight I had the heater on full speed as I normally do. Everything was find until the Gen 1 light randomly came on as bright as when the engine is off and the fan shut off. Then light went off and fan came back on. It did it one more time and again fixed itself. I decided to investigate it a little and so with the truck idling I turned on everything, my aux lights, headlights, dash light and noticed that when I turned the fan off and on a few times it would reproduce the problem and sometimes the volt gauge would dramatically drop into the yellow and sometimes it would stay in the green. When I shut the fan switch off it would jump right back into green and shut the gen 1 light off. The alternators are about 2 years old since a rebuild and neither were hot or making funny sounds. When I got home I jiggled the wires on both alts and got the gen 2 light to not come on with the engine off and the ignition on (im guessing that this is just a bad connection and unrelated as it came back on after moving the wires a little more). After that I spent about 5 minutes trying to get the problem to happen again, but it wouldn't do it. I also did notice that when the fan is turned on the volt meter dips just a bit for a second and returns and the gen 1 light dimly lights and stays like that till the fan is turned off, but that has always been the case. The gen 1 light will not come on or get brighter with anything else turned on or off, the fan is the only thing that affects it and would not work when the gen light was bright. What is happening? Oh and belts are tight with about 1/2" of play in both of them when you squeeze them by hand.
