Riddle me this - when is a "shortcut" NOT a "shortcut"?
When it involves DUG and electrical.
DH gave me TWO ways to make my front LED turn signals act as a normal car.
#1 was to get some y connectors and plug into the left rear tail light. Then run a single wire along the ENTIRE frame, up under the radiator and then disconnect the proper wire on each front light and plug into my new wire. The front LEDs would turn on when the left rear did and still flash as normal.
#2 was to quickly disconnect the harness at the light switch and run a jumper with the quicky connectors between the same wire numbers.
Option 1 is a lot more work getting dirty but the factory harness remains untouched and could be put back together normally at any time.
Option 2 was quicker, easier but harder to undo and you could mess up those old wires.
I of course went with option 2. I unplugged the harness, couldn't read any numbers tried cleaning things off when I noticed a wire that looked to be in bad shape. The spot was hard to get to and it looked like just rubbed insulation so I shot it with liquid tape. I carefully put things back, planning to go with option 1.
Of course I ended up with no headlights or tail lights at all. The iffy looking wire - #15 broke with all the movement. Everything came back apart, wire wrap tape carefully cut away and it was properly repaired. Re taped, reinstalled and Im back to where I was over an hour ago.
In some ways maybe it's a good thing I found it and fixed it now, but maybe it would have never broke if it hadn't been touched. Who knows. I'll be running a wire the length of my truck after lunch. Or when soldier B gets out of school. I shouldnt be trusted alone with electrical.
I have a pic of my flasher that I will upload later. It works with four LED lights.
