General Mcgregor
- 24
- 18
- Dover, New Hampshire
Ok Here's the problem in a nutshell...
My truck starts up fine in the cold, In NH it's been at or below +20 lately but my m35a2 fires right up every time with no need for the manifold heater.
I run her at about 1500-1800rpm until she warms up
Take her out on the road and she runs great!!! ... ...... ...........Until the temp reaches at or above the centerline...
The engine seems to loose power and die...then start running again...then die while I'm driving in gear
If I pump the throttle it seems to help, a little
It actually stalled dead on me a couple of times the other day
It seems like it's not getting enough fuel or maybe there are bubbles in the lines etc.
Oddly enough I can run it up in my driveway when I get home and I can't get it to do it, I.E. Only does it under load in gear and when warm.
When I look at my clear fuel lines it looks like there may be air bubbles leading to the injectors, But there is DEFINATELY air bubbles coming from that canister on top of the engine beside the forward valve cover
There are no visible signs of fuel leaks like dripping or anything
I bled the fuel filters and line coming up to them but I don't know how to bleed the rest
HELP PLEASE! Thank you in advance guys!
