Carl_in_NH
- 7
- 18
- Wilton NH
The good news is I went and picked up my MEP-003A at the end of last week - and thanks go to member Earth for being instrumental in its recovery. The unit appears reasonably clean, and develops good oil pressure while cranking. Inside the control cubicle it looks almost new.
The bad news is the IP needs replacement. The fuel system has a tag on it mentioning it was drained in March 2009. Put in fresh fuel, electric pumps are building plenty of pressure up to the IP inlet line. Fuel is running back into the tank via return link. Loosened all four injector lines - both at the injectors, and at the pump - no fuel is coming out of the IP during cranking. Fuel control valve is also binding, and only somewhat helped by an external application of penetrating oil. Methinks this IP is junk; while I might be able to bring it back to life, I don't have a good indoor location to store the generator while I've got the pump out to try and effect repairs - so I really don't want to disconnect everything and leave a hole in the block while I try and see if this pump can be saved.
Does anyone have a good MEP-003A injector pump they want to sell? I'd like to buy one right away and see if I can get this generator running before it gets any colder outside. Please send me a PM if you've got one for sale, and let me know what you want for it.
There are other parts I need - fuel gage is inop, and the metal cover over the injectors needs to be replaced - but all this can wait until I can make the darn thing run.
Thanks!
Thanks!
