jpekarek
- 10
- 0
- Vancouver, WA.
Hey guys! I downloaded the manual and will begin troubleshooting this weekend. I wanted to ask first if there may be a common issue here I can check first and maybe save myself some time.
The other day I was cranking the engine for a while, (10-15 seconds) trying to start it, but it was only about 25 degrees outside and she didn't want to start so I quit. Now when I go to start it, the soelenoid cluncks and the fuel pump runs fine, but the engine will not crank. I cut and replaced all of the battery cable connections and still nothing. The connections on the starter look clean but no cranky!
Is there something I should check first that may be common?
Brushes? wiring? Cables?
Thank you for any help!
