Trailer Recovery FL to LA
goldneagle
931
Slidell, LA
Can anyone help me recover a 20' box trailer from North Florida and bring it to my home in Slidell, LA. I have the truck to pull it with. I just needed someone to go with me on the recovery so I don't have to do it all on my own. It will probably be Tuesday January 18, 2011. We need to leave here Monday night in order to be there Tuesday Morning. About 350 mile drive.
I was hoping some local could volunteer to help out. Attached is the picture of the trailer.
Please PM me if you can help out. Please include a contact phone #
Thanks in advance.
73m819
319
gainesville, ga.
that is going to be a bit tough as it it not made for highway speed
hndrsonj
Senior Chief/Moderator
363
Cheyenne, WY
Looks like some kind of support equipment trailer. Without having a model number I am guessing Ron is right and you won't be towing that down the freeway.aua
DUG
73
Mesquite, NV
I assume you already asked Gimpy? Doesn't he go on pretty much every crazy recovery?
Looks like a Support Euipment trailer like Jim said. You won't be going fast at all.
hndrsonj
363
Cheyenne, WY
I'd try to get ahold of Desert Rat! He doesn't go over 25 MFH cross country!
goldneagle
931
Slidell, LA
I am going to call someone tomorrow to see what they would charge to haul it here from FL. If not I will default on it. Unless someone local would like to buy it. I have $740 into it.
DUG
73
Mesquite, NV
Problem is I have 2 weeks to get it and they only open on Tuesday mornings.
Better start Googling back roads. If you can get some weight up forward in it, she might tow better. Hard to tell without seeing the model number and knowing what it was used for.
goldneagle
931
Slidell, LA
Maintenance trailer, Year 1991, Mfg. GW Body Works Inc, repair box trailer, Mod # 1684 RTA, steel undercarrage wood floor, alumumin sides, 120 volt lighted interior, side out load ramps. Buyer Loads.
rosco
Delta Junction, Alaska
That is not something you want to tow. It will shake apart by the time you get it home. No suspension/does it have brakes/lights? The key is, do they work? Probably the front steering is not made for speeds greater the 20 MPH. Best just to load it on a gooseneck and haul it. That is a serious trip, for something that is proven roadworthy.
hndrsonj
363
Cheyenne, WY
Are you serious or is this a joke?
GE,
In 05 or 06 He went on a cross country trip and lost his high gear in the transfer case. Came back from Kentucky (I believe) with the T/C in low. He was driving a M109 towing a big trailer with a dozer on it. I'd have it towed if I were you.[thumbzup]
Jim
doghead
4 Star General /Moderator
1,176
Posted by Ken....
Just spoke with the rodent. He lost his T-CASE. He's stuck driving home in low range. He said he is running 23MPH in high gear.
We should get a interesting story opon his return.
