- 7,408
- 2,500
- Interlachen Fl.
If moving more fuel is a concern would removing the EMR. shut down valve help?
There is a lot of discussion about replacing all of the #10 fuel line and filter all the way to the tank and upgrade it to #12 with a new filter head. I may do this someday but I have no desire to crawl around in the mud this time of year.So with increased fuel demand do you feel that the lines leading from the tank all the way to the pump are large enough? Do we leave them alone or try to increase there size to?
When you split your lines would you not just split them as the came from the pump and one runs to the front head and one to the rear head?
The end result will be similar for both as they are both similar in the design.a pic of the dual line setup would be nice, is there any reason to put it on a nhc250?
Not to hi-jack this thread in any way, but... Seems to me that by the time you spend about $5,000 on a turbo set up for the 250 and then even more if you wanted to intercool it....The end result will be similar for both as they are both similar in the design.
Combining this with the turbo kit would be the first steps I would do towards getting more power.
I wonder if anyone has installed a Inter-cooler on these trucks.
One of the problems you run in to with turbo charging a NTC 250, is the fact that this engine does not have any piston cooling oil squirters, that keep the pistons from melting in the later Big Cam engines, when working them hard. The turbo kit for the 250 was originally designed, more for altitude compensation and to reduce black smoke, then to make serious power.Not to hi-jack this thread in any way, but... Seems to me that by the time you spend about $5,000 on a turbo set up for the 250 and then even more if you wanted to intercool it....
NOTE: I am working off the info that I was given that the turbo kit for the 250 is in the $5k price range (without intercooler).
I certainly understand the more reasonably priced "hop-up" options and tuning, but when you get close to $5k for a mod you have to start to wonder....
For about $5k you could put a 350hp turbocharged, intercooled 5.9 in the truck and still have the option to massage it to give something close to or in the 500hp range should you really want to...
It is significantly more work to do a complete engine change than to simply install a turbo, and it does alter the truck from being historically correct (but so does installing a turbo...lol) But in the end you'll have far more available power for about the same financial investment.
If the 250 was a multi-fuel I could see the post-apocalyptic scenario for availability of fuel as an argument but being the 250 is diesel only that does not apply...
I'm just sayin....
And now, back to your main topic....
Soni, That is very good info to know! - Thanks!One of the problems you run in to with turbo charging a NTC 250, is the fact that this engine does not have any piston cooling oil squirters, that keep the pistons from melting in the later Big Cam engines, when working them hard. The turbo kit for the 250 was originally designed, more for altitude compensation and to reduce black smoke, then to make serious power.
Will a 350/400 fit in a Deuce? Weight issue?It is my opinion that one is better off swaping in a Big Cam 350 or 400 if you want power and reliabillity. (I would not use the 5.9B in a 5 ton) If you don't run jake brakes it will fit right under the stock hood.
Soni
Might want to post that one in the hotrod Deuce forum?Soni, That is very good info to know! - Thanks!
Thought about that but since "the issue" was brought up here and it was only a small part of the post I figured it was maybe OK here....Might want to post that one in the hotrod Deuce forum?
Other than displacement, what other significant differences are there between the 350 and 400?
Is there an automatic transmission (Preferably with OD) that will work with the 400?
Would there be any reason to go with the 350 instead of the 400?
That's funny I posted its brother earlier. I choose the one I used because it showed where the fuel plug was better. At least IMO.Here is a pic I found of the overall look of the dual fuel mod.
Looking at eh pictures make you wonder why they didn't do that in the first place.
You are absolutely correct, the turbo, if properly installed and with the right amount of fuel, will run lower EGTs and won't hurt the NTC 250 at all. It will actually give you better fuel milage and a bit more power ....I was talking, if you turn up the fuel on it, to try to get more then 50 extra hp, and start pulling hard, with heavy loads..... then IT WILL MELT THE PISTONS!!!..... Don't ask me how I know this..... lolthe turbo kit I have only cost about 2k. it would be 5k if you bought all new parts.
The EGT's on the 250 when I run them turbo'd are lower than stock so in theory it should last longer not shorter.
