PawnShopEd
- 0
- 0
- Churchville / md
hey guys one of my deuces I just picked up to make a plow truck out of suddenly started giving me a problem.
I recently bought the truck it was running perfectly. throttle would stick a little at first and I got a bit of white smoke when you'd accellerate. But other then that ran like a top. The fuel was horribly stale and like turpentine. I ran the rest of the tank out and figured it just ran out of fuel when it started to sound like it was sputtering so I shut her down. PIcked up 15 gallons of diesel and 5 gallons of fresh motor oil. Went in to turn it on and she just cranked and I figured it may of picked up some crap from the bottom in the fuel filters. So I changed the two secondary filters first and then cracked and bled and it was spitting fuel out beautifully. The existing filters inside were shot and had a thick caramel like sludge everywhere. So i figured with fuel there so heathily then the primary should be fine. went and cranked it to start and still turns over great but doesn't start. Not sure what happened exactly. I tried moveing the cut off rod in and out and makeing sure it wasnt stuck and makeing sure the throttle cable was moveing freeley at the injection pump but still nothing. I'm guessing the problem is somewhere within the injection pump, is there a way to test to make sure thats what it would be. I have 3 or 4 spare pumps but if it's something simple I don't want to have to use one up lol.
Thanks as always.
Thanks as always.
