OldDominionIron2
- 1
- 0
- Hampton, VA
Getting ready to do the first fluid/filter change on my M35A2 since I got it. I'm hoping to see a little mileage increase from the new filters. I was wondering if it is worth pulling the oilpan and cleaning it out, and if so, questioning whether I should wait to get a new oil pan gasket or just use Permatex Ultra Black sealant as a replacement gasket. I understand that using the Permatex requires letting it set up for a little bit before tightening, and checking the torque after it's run for a few hours (at least that's what a lot of the posts I've read say about it).
Let me know your experiences with deuce oil pan work. I have the TM's.
Also, do you really have to pull the fuel filter assembly out of the truck to replace the filters (like the TM has you do) or can you pull the cans and replace the filter elements with the assembly on the truck. The plan now is to pull the assembly as per the TM. I understand there are some small pieces that like to get lost.
Thanks.
Thanks.
