I'm thinking about changing from the Oil that came in it to Dexron. I've read all the threads below. The book says the capacity is 16 qts to drain and fill, 20 qts if dry (installing a rebuilt tranny?) and 22 qts total (includes cooler and lines?). I liked the idea of removing the return line from the cooler and refilling as it runs out to get it all, including the torque converter. However, the transmission fill tube runs into the pan at the very bottom. The outlet to and return line from the cooler are at the top. How can I be sure I'm getting it all and the new fluid isn't just being put into the bottom and then taking a short route and being pushed out at the top, engine running, leaving oil in the tranny? If I drain and fill, getting 75%, run the truck, then drain and fill again, leaving 6% of the original fluid in the tranny, is this OK? If the engine oil and Dexron are compatible I think that would be easiest, although expensive with Dexron III being $10 a gallon. We have a local Allison Dealer here but I've found getting the right info from dealers isn't always easy or possible. Thoughts from the board please.
