sponaugle
- 0
- 0
- Portland, Oregon
I recently swapped the stock NDTs for a set of 395s on Super Singles. After the swap I noticed the the front axel set of the tandem set is shifted a bit to one side. It was not really noticeable with the NDTs, but is a bit more obvious with the Goodyears.
I have attached three pictures. One shows the offset from the view of one of the tires (note the offset is not as big as the picture shows due to me not being right on the edge of the tire).
The second and third picture show the under suspension on the drivers side viewed from the front and rear. The front tandem is pushed in a bit on the drivers side, and sticks out a bit on the passenger side when compared to the rear.
I suppose without a real reference, I am not sure which axel set is moved, as I am looking relative to each other.
You can see the leafspring for one axel is to one side, and on the other side for other axel. What provides the centering reference?
Jeff
Jeff
