I looked for the NSN online real quick....didn't find it; and it is way to dark and cold right now to go grab it. It is just the "Quick Start" cylinder that squirts ether into the stream when you hold and release the cold start switch.
I was under the impression that NAPA, while carrying starter fluid, would not contain the ether mix used by the actual NSN item. I would prefer to go with the real McCoy if possible...
EDIT: I might have found the NSN...possibly 2910006469727
according to TM 9-2320-386-24P, i think you are correct...
32 PAOZZ 2910006469727 6Y402 8200327 CYLINDER,ENGINE STA................. 1
the cage code is 6y402 and comes back to:
PHILLIPS TEMRO INC
DIV OF BUDD CO INC 9400 W 74TH ST
EDEN PRAIRIE, MN 55344
800-328-6108
i guess with the cage code i can call napa...
i don't care if its the original or a suitable replacement, so if anyone has a part#, please feel free to share... thx
mikey
