rat4spd
- 10
- 0
- Evansdale, Iowa
There's hope yet for you Dug. We'll get your status upgraded someday.
Time to update your avatar. I agree that a hole between the fifst and second factory holes would be nice. I would have to pull them apart though to drill the holes because I know my luck.Install wasn't too bad. I want to lower them some, but not all the way to the next adjusting hole. I might end up CAREFULLY drilling my own holes.
What I have done before is wrap tape so it prevents the drill bit from going in too far and hitting the wires. Then I would drill through each side instead of going all the way through. It's still risky and I may not do it, but it is possible.Time to update your avatar. I agree that a hole between the fifst and second factory holes would be nice. I would have to pull them apart though to drill the holes because I know my luck.
Nice idea.I installed a brake warning light from a HMMWV to remind me the convoy lights are on. A little brake cleaner removed the work "BRAKE" from the red lens of the light.
You see how easy they adjust up and down? The pic is all the way down. I would like them up another 6 inches but there's no hole there. I might have to CAREFULLY do my own.Looks great!
