glcaines
- 2,524
- Hiawassee, Georgia
I now have the official word from Castrol and Allison on the compatibility of TranSynd and motor oil. I have heard concerns that to switch to TranSynd, that it is better to switch to Dexron III first and then go to TranSynd. I plan on replacing the motor oil in my Allison 1545P with TranSynd. Here is what I found out directly from Castrol Technical Service.
Question for Castrol:
I have an Allison 1545P transmission with 10w-30w
motor oil in it and would like to convert to TranSynd fluid. The military uses motor oil instead of TM fluid. I have been told that motor oil is not compatible with TranSynd and that I should instead convert to Dexron III by draining and filling. Can I safely drain and fill 2 - 3 times with TranSynd to purge the system of motor oil? I'm concerned about any potential compatibility problems between motor oil and TranSynd.
Answer:
Thank you for contacting Castrol,
Castrol Transynd will be compatible with motor oil; however it will require several transmission fluid flushes to purge the system of motor oil.
Castrol Consumer Relations
I still most likely will purge with Dexron III several times first just to get rid of the motor oil with a less expensive fluid. I also contacted Allison by telephone (very difficult) and they told me basically the same thing as Castrol. Allison also told me that there is absolutely no problem with using Dexron III - it simply needs to be changed more often. Allison told me that the transmission will work just as well with Dexron III as TranSynd, but to be very careful since Dexron III is no longer certified by GM. I was also warned very strongly NOT to use Dexron VI as it will eat up the seals in a 1545P transmission.
Answer:
