wsucougarx
- 65
- 48
- Washington State
wow that rustoleum flat brown looks like an exact match to the 3 camo carc brown. What did you use for the base green? Is that rustoleum as well?
+1What did you use for the base green? Is that rustoleum as well?
It was between 50 and 55 F I think.I started on mine with the RAPCO rattle cans but it has been too cold and too windy. Got in an hour of painting this weekend and 1 hour last weekend. It is my understanding one needs at least 55 degrees temp farenheit for good results. What was your outside temp when you were painting with snow on the ground? I could swear my paint was acting a little funny during application when the temp dropped to about 48 degrees. Your truck looks great!
I also like the jerry cans on the mud flaps.
I had to spread out the mud flap supports a bit.
That seems to be an excellent location for additional Jerry CansDid you do anything "special" back there, or simply bolt the trays to the mudflaps
Thanks.I had to spread out the mud flap supports a bit.
