Rattlewagon
- 1
- 16
- SW PA
what fender is the air filther on?It's 10 lug. Heck yeah baby!
Right side, same as exhaust if I remember correctly.what fender is the air filther on?
That's all part of the MV addiction...it just happens.So you bought somthing not even knowing what it was....?
More than likely a multi. Cummins were on the left side.Right side, same as exhaust if I remember correctly.
Isn't the rubber just a protector for the piano style hinges?If its pretty ratty make sure you get ontop of the back and check out the rubber hinges befor you open it up (raise the wings) like the picture above. If the rubber has rotted out the sides will fall off when you try to open it.
You cant go wrong with a 5T for $1500
You might be right. (I dont know for a fact) but I have heard of guys getting these and haveing the rubber rotted out and the side come loose. It could be that the rubber covers the hinge and if its rotted and leaks maybe the hinges get rusted out and loose.Isn't the rubber just a protector for the piano style hinges?
No, the rubber is the hinge.Isn't the rubber just a protector for the piano style hinges?
Ok, so the next dumb question. What's the easiest way to tell if it's a duece or a 5 ton?
