91W350
- 57
- 48
- Salina, Kansas
I had not attempted backing the M105 with the deuce, so I had to try it today. I hooked her up and took the dogs out for a run. The deuce sure pulls that trailer easy! It really is one of those you do not know its back there deals, but it does bounce on the hitch once in a while. Truck and trailer stopped nice and straight. I had no problem backing up out there in the field, but when it came time to twist it back into the driveway between the houses, I discovered it is hard to recover once that trailer gets started around, the steering just is not fast enough turning to get back in line. I had to straighten out three or four times to get it wormed in there. The drive is hard to hit with the deuce and no trailer.... The M1008 makes putting the trailer away so much easier! Anyway, maybe I will get better with practice. Having 200 plus pounds of dog wanting to look out the right door glass and covering up the mirror did not help my cause much, like not at all..... Anyway, it was not any worse than I imagined, Glen
