- 7,408
- 2,500
- Interlachen Fl.
treeguy; Also why is the valve cover vent open to the out side atmosphere and not connected in some way to the trucks air intake to burn as combustion? Isn't this how most vehicles are set up said:That to I believe is part of the fording kit. slobber tube/ crank case breather gets extended with rubber hose above water line. PCV is more for emissions and is realy just dead air no advantage to burn it.
No problems but you would think the path of least restence will always be the input shaft.
