Restoring front fender non-skid finish!
Tinwoodsman
76
Comfort, Texas
I am in the process of bobbing my deuce and am refinishing each part as I get to it. As far as the front fenders are concerned, are there any recommendations as to how to handle the non-skid area between the two ribs on the front fenders?
Flyingvan911
158
Kansas City, MO
What are you trying to do? Do you want to remove the antiskid or put some on? To add it you could mix some course sand and paint in a bowl and mix it or used a bed coating like Herculiner. To remove it I'd guess get some course sanding disks and sand it off. Some guys might have better ideas.
Floridianson
2,503
Interlachen Fl.
Yea all depends if you want it like they did it or just remove and lay down a black sheet of nonskid. The outher way would be do you realy need nonskid there.
Tinwoodsman
76
Comfort, Texas
I guess I should have made myself more clear. I want to keep the non-skid area when I refinish the fenders. At my age, I need all the help I can get. I might try the same in the paint method. Thanks,
DieselBob
15
Arnold Maryland
My truck came with the non-skid on the entire horizontal surface of the front fenders and on the entire top edge of the front bumper. I really like it especially when its wet and I am climbing around to check the oil etc. Mine just looks like sand mixed in when it was painted.
DHennon
Orlando, Fl
I took off my antiskid with a 4" grinder with a wire cup attached, then applied Herculiner. I am also doing the steps.2cents
Tinwoodsman
76
Comfort, Texas
My non-skid is only between the ribs on the fenders. I was considering Herculiner but wonder if I can paint it with Rapco 383 CARC substitute?
DHennon
Orlando, Fl
I am spraying my truck with Wally World Krylon Camo Olive. I am planning on spraying over the Herculiner. I tested the right front fender and it seems to be covering and adhering. Not sure how the Rapco would work. A call to Rapco might be the best way to answer that question.:idea:
glcaines
2,595
Hiawassee, Georgia
The anti-skid on the fenders and front bumper on my M35s is great. I have an M149A2 water buffalo and I slipped off the fender and busted my *ss when I hit the ground. The water buffalo should have it as well. The M35s appear to be sand mixed with paint. I think the sand/paint mix look better than the sheets of anti-skid.
wiggall
151
Lenore, Id.
The Boatsanmates tried to do this, and it came out a BIG MESS! The way we did it was to paint the area that we wanted non skid on was to put DRY SAND on the wet paint. Let dry remove excess sand put another coat of paint on it then more dry sand, let dry, remove excess sand. Then paint with last coat of paint, and let dry. When you mix the sand in the paint it is hard to get an even coat, and it does not dry good.
RANDYDIRT
Furlow Ar.
3M makes some kick as$ non skid. It's like a thin shingle with an adhesive backing and it comes in a roll in varying widths. Think I got mine from WW Grainger.
Dirt
wsucougarx
67
Washington State
I went to Home Depot and bought some epoxy deck paint for my 109. I noticed they had a pack of dry powder from Behr that can be added to paint. It's suppose to add the non-skid finish to the porch paint. Wonder if that'll work?
zout
154
Columbus Georgia
I've tried the paint w/sand method and several other including the adhesive.
What I have found best is the Herculiner as it has the grit in it already - I used a paint stirer on the end of my drill to mix it. Laid out painters tape and laid it on in 2 thick coats - BEFORE the stuff dried I removed the tape.
You do not want to run bare skin over this stuff when it is dry - because you will have no hide left - it is tough.
I have sprayed Rapco and CARC over this product and it has no issues at all with adhesion.
If you get the stuff - be sure to clean out the lip of the gallon can if you have more product left - if you do not - you will destroy the lid trying to pry it off.
Maverick1701
181
Lubbock, TX
mine was too!
I like mine as well...but it doesnt rain too much out here so it doesnt get slippery lol
