M1008 1GCGD3 No H?Is your truck an M1008 or M1028?
what are the first 5 letters of your vin?
Yea I was in 4 Low at the time. Is there any way to verify the axle as open/lsd without taking off the diff cover?Did you try 4 low?
If you had it in 4wd then yes. The front axle is open and after traction is lost only one tire will spin at a time. However it is possible that one of the front tires started to spin then grabbed allowing the other front tire to spin.
ok I will give that a try this weekend.Jack up the axle and spin one tire. If both rotate in the same direction then it has a locker.
