rnrracing
- 1
- 0
- Vancouver Wa
Do you know if anyone has changed out the the gear sets in the rear ends to lower the rpms at 60 mph freeway speeds?
Found this on a fast search, not what you asked, but.... and I do ??remember?? someone doing pumpkin gear changes, major machining though.Do you know if anyone has changed out the the gear sets in the rear ends to lower the rpms at 60 mph freeway speeds?
I need to adjust the toe. My understanding is that with bigger tires you need some toe in. Toe out affects turn in. I'm not looking for turn in ability but straight line stability which is helped with a slight toe in on the front wheels.You mean toe out.....
9.00s are 41 inches 11.00s-14.5s are 43inches and 15.5s-395s are 46 inches.I was planning on putting 46" tires on my A3 and was trying to calculate how much speed I could gain.
Top speed with the 42" M35A3 stock tires id 55MPH screaming.
From 42-46" is a 9.5% increase, so I calculated my top speed to be 60MPH
Is that right?
What size tires do the A2's have in inches? They must be considerably smaller if you are able to reach 70 MPH.
Does anyone know how the tire sizes convert to tire size in inches? I cant figure out how the military tire sizes work.
Thanks in advance
