steved454
- 0
- 0
- brandon/ms
First off I read through the forums and did not find what I needed, If we keep this thread I hope this will help others.
I got a set of the 37 inch humvee radials a few months ago. I thought about getting the Hummer H1 wheels but instead got the pro comp 16.5 inch wheels from 4wheelparts. I got the 16.5 x 9.45( this is where I went wrong) I have bought the wheels before on other projects and figured they would be fine with the 37 inch tires.( wrong). At the tire place they tried everything to get them to seal but no luck. I did not research the site like I should have. there is a member here who got the 16.5 inch x6.75 wheels( standard factory size). I can not say how important it is to research all the great info here! I then sent them back. I had a set of standard wheel I had gotten years ago and thought that would be the way to go. I had them cleaned and powder coated black, ($180 ) got them put on and WOW they looked assume!. Went to drive it home and almost killed myself from the death wobble!Went back to the tire place and found out that 3 of the wheels where bent!
So now I ordered a set of procomp 16.5 inch x 6.75 wheels from 4wheelparts. They do not have any more and not sure if they are getting anymore!!!!!
ok all that to ask one question. I know that the H1 wheels are 8 inches wide( atleast that is what I read) so do you think I can get a set of 16.5 inch x 8 wheels? hate to go through all this again and not get it write this time.
thanks again fall all the help I have had on this site.( Mental note" always look through threads before buying anything!!!!!!!!!!!!"
