- 330
- 3
- 0
- greenville sc
Does anybody know what that protective stuff is that Uncle Sam uses on the winch cable, it works most excellent and I would like to get some to put on my winch cable.
My neighbors great dane lubes mine up every morningDoes anybody know what that protective stuff is that Uncle Sam uses on the winch cable, it works most excellent and I would like to get some to put on my winch cable.
^^^x2 That's good stuff.Go to Napa or Carquest and get a can of chain&cable lube. Bellray or Clyco(used by the dirtbike/atv guys too) Comes in a aresol can. Goes on good and dries so it does not attract dirt or make a mess out of You. I use it on my drilling rig as it does not wash off as easily as motor/gear oil.
That's what I use. Good stuff!Go to Napa or Carquest and get a can of chain&cable lube. Bellray or Clyco(used by the dirtbike/atv guys too) Comes in a aresol can. Goes on good and dries so it does not attract dirt or make a mess out of You. I use it on my drilling rig as it does not wash off as easily as motor/gear oil.
Yes I can see a drum cover holding moisture but I just cover the whole winch and it's open on the bottom just as a rain shed. I used the old canves end cover and it seem to be working good. Even has the flap to let mosture out right. I just kick it off when I use the truck.A drum cover looks good but is not the best IDEA, the reason is because the cover will hold/trap moisture, which in turn will cause rust
