ODdave
- 41
- 0
- lansing michigan
What about the regulator? can i use the same one i have for my acetylene? I have a VERY expensive set and dont want them damaged. I am definatly thinking of switching!
Nope , it will just raise the price of propane .Maybe this will reduce the threats that say " buy this truck before I take the flame wrench to it and scrap it "
I would check with the manufacturer on your regulator or your gas supply store. I was able to just use my regulator. If in doubt you could just buy an inexpensive new fuel gas regulator and save your good one. As I said before get new hoses for use with propane, and the proper tip for your outfit. I like the tips for propane better for cutting because they are two piece and easier to take apart and clean out the slag. As far as different cylinders and valves, I just use a gas grill tank - keep a couple on hand. - Easy.What about the regulator? can i use the same one i have for my acetylene? I have a VERY expensive set and dont want them damaged. I am definatly thinking of switching!
LP is more stable but it doesn't burn as hot as acetylene.It's more stable and burns hotter.
I use all of that plus my Dilithium Crystal Warp Accelerator, Cellulose tipped scrutinizer and Protracted Pubimium Sphincter apparatus.You can heat them with the plasma BUT its makes a real mess of them.
I use my acy only for heating things like that. Plasma for mutiple cutting. water jets for unusual cuttings. and laser cutters for those fine detailed cuts.
