Lonesome715
- 24
- 38
- Columbus, GA
How do I get the electronic valve to work if that is the problem? Also, is it something I can just eleminate?
It might be the intake temp sensor for the KSB valve. Can't make it out too well, but that engine has limited electronics on it. The only electrical thing that won't let it start is the shut off sol. You said something about rusty fuel in the filter in a prior post, IF the rust/rust causing contaminent got past the filter, you could have a damaged pump.Then what is the thing just above the fuel filter. It has a broken connector.
Thanks for the break downs thoae are a big help in understanding hwo these parts work.
I do nto have a meter to check the selonoid.
