Couple questions on the tracks with external track guides. It appears mechanically (from photos) that the connector locks to the pin(s). That is, the pin does not rotate at the connector?
Does the pin rotate within the track itself?
It also appears from photos that the coupler is welded to the guide? Is the guide a cast part or stamped?... and welded to the coupler?
Thank you,
JC
Thank you,
JC
