I do not know anyone with trucking equipment much less a lowboy. I did get a uship bid of $1300 to move the truck. But I would rather put the money towards parts for the M328.
Do you mean a cdl learners permit or a trip permit?
I meant the learners permit. You only need to have your DOT physical and take the 'written' tests at the local DOL. The tests are pretty darn easy really, and are on a computer. So you just skip the ones you don't know, and do as many of the ones you know until you are forced to take the ones you skipped. Stupidly easy really.
If you are going this route, I suggest the class A. It is actually required for towing anything with a GVWR greater then 10,000 lbs.
If your got your permit (good for one year), you can drive the trucks as long as a CDL driver is with you. Which, for the sake of this trip, would cover your butt for the trip back, and let you switch drivers as needed.
I have a flat bed trailer, but it doesn't look like you can get that front section of the bed any lower then it already is. If not for that, you can load it on it, and lower the windshield, top, exhaust stack, etc. And be under the height limit.
