TexAndy
- 15
- 38
- Bee County, Texas
Picked up a deuce from san antonio last week. It's in good shape, except the middle axle is about 1.5 inches moved over to the right.
Causing excessive wear on the tires and I assume everything else inside the axle housing.
What's the best way to fix this?
One idea I had was to back the truck up onto a ramp until the middle axle was off the ground. Then loosen the U-bolts, park another deuce along side, and use the second truck as something to push against with a bottle jack.
Or maybe use a tree or something as an anchor and pull from the other side with a comealong or something?
