sn8ke8
- 1
- 0
- Saginaw, MI
Harley I'm in Saginaw mi and was wondering if I could check out your setup, I would like to buy one but I would like to see a setup, thanx David 989-213-1767
Thats not a problem. I just need to get my hands on some more oil. Send me a PM sometime next week, I'm heading to the east side of PA later this week so I won't be around. Just keep in mind I'm still getting my final setup in place, but its operational. Eventually I'll be moving all but the heating operation into my shop and permenantly mounting the centrifuge.Harley I'm in Saginaw mi and was wondering if I could check out your setup, I would like to buy one but I would like to see a setup, thanx David 989-213-1767
I like this one that just sold on GL for around 12k and cost 300k in tax money
Try 6000gph. and never used. I called the manufacture and they had parts instock for the model. Just to rich for me today.
Having done this for years now I can tell you you don't have to heat it above 160 deg for the water to fall out. My setup has an upside down barrel with a drain in the 3/4 top bung hole and the run valve welded in about 2" from the"bottom" drain. Then I cut the bottom of the barrel out and found a lid that covers it well. Once it has been uniformly heated the water falls to the bottom and can be drained off, along with some of the heavies. The centrifuge catches the rest. YOU CANNOT REMOVE LARGE QUANTITIES OF WATER WITH A CENTRIFUGE ALONE, Unless your bowl is freakin huge. Heating above 212 deg will work but can burn the oil and the water actually boils off which can be dangerous (ie spatter). The black is Ok I run a blended WVO with a little WMO and diesel so it runs nice in my Benz and m1009 and deuce. I use an electric barrel heater for mine so it's a little safer (no exposed flames) as mine is semi close to the house.
I thought it brought at last sight 12k and it weighed 1300 lbs and clamed to do 6000. I believe it was for a big ship and did the oil while it was running. 440 3 phz.I work for that company....and yes.....they are expensive....and I don't think it will do 6000gph.....when did that get auctioned????
