mounting tires
roklogan
palmetto GEORGIA
im new on this site and learning , need to know if anyone has any tips for getting the 14.5 r20 tire compressed enough to get the lock ring in place on stock deuce rims ??????
combat32
106
Booneville AR.
I have mounted deuce tires in the field when I was in the Army.I would drive up on the tire with the front wheel to compress it enough to get the ring seated.There are a lot of ways to skin that cat,
roklogan
palmetto GEORGIA
tire mounting need help suggestions please
new to computer use and this sight need any suggestions or tricks some of you might know on how to get a 14.5 tire compressed to get the lock ring in place when mountin on stock deuce rims i ve seen lots of these on the lock ring rims and know it can be done .....agian i do not know how to use this site properly yet please pm me with any and all suggestions and thank you all very much form your fellow deuce enthusiest..........
gringeltaube
Staff Member
2,526
Montevideo/Uruguay
gringeltaube
Staff Member
2,526
Montevideo/Uruguay
More than knowing what "can" be done you should know (or learn) what should or should not be done. I already responded to your other thread: you should NOT mount the 14.5 on a Deuce rim, for your own and others safety!
And also, you should NOT "Cross-post multiple posts or threads about the same topic." It's against the rules... sorry.
G.
