Differential and sprag or other system
Robo McDuff
In memorial Ron - 73M819
1,565
Czech Republic
OK. Somebody explain me this.
1973 5-ton M51 A2 Multifuel
Front wheels jacked up and free, rear wheels on the ground.
Both front wheels free, when turning one it will turn the other in opposit direction.
In neutral AND in forward gear, keeping one front wheel fixed (not turning) and the other free. If I turn that free wheel forward, it moves the cardan shaft (between front differential and tranny). If I try move it backwards, no movement.
Gear in backward, I can move the free wheel backward but not forward.
I thought that on a permament 6x6, when gearbok and tranny are engaged, its impossible to turn the cardan shaft?
Is this the effect of a sprag? I thought later models did not have that?
gringeltaube
Staff Member
2,640
Montevideo/Uruguay
Your's is NOT "permanent" or full-time 6WD.
YES. Front axle is driven "on demand" only. All early 5tons including 800series came that way, same as Deuces with sprag T-cases.
G.
Robo McDuff
1,565
Czech Republic
Thanks, so that behavior was normal?
When does the thing jumps in? I can't reach my manuals today to check myself, I am using internet away from home.
Robo McDuff
1,565
Czech Republic
Thanks. Not that I planned to do it, but putting front-wheel locking hubs on your 5-ton for highway work is nonsense in that case.
So basically I have a 4x6 on highway and 6x6 in the mud. Great. Learned several new things today, both from praxis and from this forum.
