M116A2 trailer VIN / serial #'s
flyxpl
9
Chatham IL
I have two M116A2 trailers I am reqeusting SF 97's for . I see a VIN on the data plate , but both trailers have the same VIN . Is thier a seperate serial number I am not aware of ? I have looked and can't find anything .
Nonotagain
41
Parkville, MD
The only numbers are on the frame data plate mounted on the drivers side frame rail.
http://www.steelsoldiers.com/members/nonotagain-albums-m116a3-picture5942-m116a4-id3.html
What does your GL invoice list as the numbers? Did you inspect the numbers before removing the trailers from GL?
319
Lieutenant
57
Michigan
Are the trailers the same year? Same VIN is common on some M116A2s. I had two I had picked up from Ft Drum with the same VIN. There is a thread from last fall regading this very subject.
flyxpl
9
Chatham IL
I believe they are the same year . These were purchased through GSA . They were listed as gens. only even though they were sitting on trailers . GSA will not send a SF 97 unless they are requested . Since listed as gens they have no info on the trailers . If I send these both in at the same time I am sure it will cause problems . I did get the nins on the left side of the frame rail .
ptg530C
almont, mi.
Trailers.......get it weighed at a truck scale and then send the weight slip to dan at detroit vintage cycle and he will get you a michigan "homebuilt" tag. in michigan trailers pay one time for a plate, $75.00. michigan does not title trailers, the registration with the plate is proof of ownership. once you get a plate, they will also give you an "application for title"
and they will send you a title if you want for a fee. one more thing, the trailer MUST weigh
LESS THAN 2500LBS. i have 4 trailers bought thru gl and that is how i did it.
Also, for a vin you can use anything you want. call it 14 or whatever because it is now "homebuilt".
flyxpl
9
Chatham IL
I have a few trailers I built with homemade titles . I prefer to not get homemade titles unless I have to . I may use the vins off of the gens .
