PCA16
- 0
- 0
- Smethport,PA
I have a m920 that i removed the winch from, mounted it on the front, and installed a dump body and hoist on the back. Now, i have run the hydraulic lines from the pump to the winch and hoist. The front line is run to the hoist, which works. The rear supply line is run to the winch, which does not work. Now if i switch the supply lines i can reverse the above and have the winch work and then the hoist does not. Any thoughts?
