WMO and what filter grades to use?
goldneagle
983
Slidell, LA
I am working on a WMO filtering system. It will incorporate a Military Fuel Water separator rated at 50 GPM. I bought it new a few years ago but never got to using it. I plan on running the WMO through some bag filters first and them pump it through the Water separator. There will be a 11 micron final stage filter after the water separator.
My question is: What is the rating of the secondary fuel filters on the M35? Is 11 microns fine enough for the final particle size to use in my multifuel?
I will have pictures of the setup once i get the part together.
goldneagle
983
Slidell, LA
PS...
Does anyone know what the micron rating is on the 4 filters inside the Military Fuel Water Separator rated 50 GPM?
Jimma
Hartwell, GA
I use various filter bags from Dudadiesel in Alabama. They are resasonably priced, ship fast, have a huge selection and a nice web site. I usually filter to either 5 micron or 1 micron depending on what filtlers I have. 5 micon should be good. If you only filter to 11 youmay clog your primary fuel filter on the truck a little quicker.
cbvet
20
Northwest (Knox) Indiana
I use 100, 20, & 1 micron when I have time. If in a hurry I might use just the 1 micron & replace it after 100 gallons. That's less than a dollar a gallon.
If I use all three filters, average cost per gallon is about 20 cents.
goldneagle
983
Slidell, LA
WOW this thread came to a screeching halt fast! I thought more members would chime in. I know there are plenty of members that filter their own oil. Where are you? :roll:
goldneagle
983
Slidell, LA
I am new to the WMO scene. I am currently looking for oil , barrels, and filters to start my set up. I have a 525 gallon ag tank, and a 250 gallon oil tank that I can collect in of fill. I used to see barrels all over the place, but now that I'm looking I cant seem to find any. I have about 100 gallons of WVO that I was going to make bio diesel with I got a HWH and then things came to a halt. I am looking for all the info I can so I can start. Thanks Jim
Actually I am also looking for containers for the oil. I got 3 drums from my friend Don last week. I am looking for a 275 gallon TOTE (Large plastic container on a pallet reinforced with a metal cage) to use as the collection container. I will install it in my M105 trailer and tow it with my Deuce to collect oil from local shops.
If anyone has access to a cheap Totes let me know. i am in Louisiana so I prefer as close as possible.:grd:
I found this tote in Madison, GA. Anyone near there that can get it closer to Louisiana?
'48Chevy6
Western Maryland
check local waste water treatment plants I got five free just to haul off for them. do you know if 90wt gearlube can be used as fuel they have a steady supply of this also.
Yes, gear oil can be used.
Yes, it will stink.
Yes, it will smoke more than anything else I have tried. I avoid it if possible.
Tim
eagle4g63
34
North/west Indiana
I just ran some new(old barrel that was around for quite a few years but still sealed new) 90w gear lube and used some (5gal) mixed with about 10 gallons of diesel. Idles fine but runs a little sluggish. Might not have thinned it enough.
