Aircraft tug
RealCavDog
12
Joplin, Missouri
Now that is tooo cooool ! I could really see a bunch of awesome uses for that beauty !
Most of them shock-value or head -scratching based ! :jumpin:
If there are any more pictures or information on these, that would be great !
steelypip
68
Charlottesville, VA
From before my time. By the '70s those were all replaced with tugs that look very much like a large airport has. All those windows make a lot of sense for checking status of the tow bar and tow and for backing. I bet they begged for air conditioning, though - it's always pretty hot on the flight line and that cab doesn't look like it would catch a lot of breeze.
Airplanes as big as BUFs and B-36s get dragged around a lot - starting engines to taxi down the flight line is a major (expensive) event.
Knowing how fragile and unreliable (prone to overheat) the recip powerplants on the B-36 were, I suspect they didn't start them until they knew for sure that they were really going flying....
Bighurt
46
Minot, ND
Couldn't find a weight....
The current Dragon's, UTE's, MB-2 whatever you call them we use for the BUFF is a beastly machine, and gets a lot of use...
Steely was right nothing with 8 engines is cheap to start or fly...
DUUANE
122
Qualicum Beach BC
Ive been using mine in its modified state for a few years now..its a beast..and its truly a rubber tired locomotive..ive used it to drag tandem truck around with the brakes all locked up and had 10,000# swinging from the jib while driving around in the yard..you can hardly tell theres any load on it..its simply the most fun pull-your-house-down toy ive had..makes my tridem dump seem like a lightweight.12.jpg
