- 12,195
- 319
- 0
- gainesville, ga.
Yes
If you are talking deuce, then use a air shift tcase , the front drive out of the tcase is a in/out clutch not a over running clutch, this ought to work a lot better for you'
If you don't have air, with some thought, I bet you could make the air shift manual, by removing the air piston, making a cover with a seal for the hole, and then connect the shift rod to linkage to the cab
